I'm using Virtual Scrolling on the WebDataGrid in Infragistics ASP.Net 2011 Vol 2
This is only effecting Chrome (Version 36.0.1985.125 m). Is working fine in latest version of Firefox, Safari, IE 7, 8, 9 & 10
Here you can see the headings are misaligned with the data (They are supposed to be fixed width at 150px)
When you scroll to the right you can see the data moves quicker than the headings. As you get all the way to the right, the headings gradually grow to the correct size. It's like the total width of the headings is smaller than the total width of the data.
I've removed custom styles and unnecessary features but this is still happening in Chrome only
<igtbl:WebDataGrid ID="uwgDrilldown" runat="server" Width="100%" Height="100%" DefaultColumnWidth="150px"> <Behaviors> <igtbl:VirtualScrolling ThresholdFactor="10" TooltipVisibility="True" AverageRowHeight="29"></igtbl:VirtualScrolling> </Behaviors> </igtbl:WebDataGrid>
Switching on ColumnFixing seems to make it work... but then that feature is causing issues in Internet Explorer where by (upon fixing a column) the first row is the only one that moves to the right. All other rows stay fixed. This is very frustrating!
Any help would be greatly appreciated
I've found that I can enable ColumnFixing to correct the issue I'm having in Chrome. Then I can hide the "FixButtons" to avoid the user from actually fixing a column (which is then avoiding the problem I have in IE). ppffft
<igtbl:WebDataGrid ID="uwgDrilldown" runat="server" Width="100%" Height="100%" DefaultColumnWidth="150px"><Behaviors> <igtbl:ColumnFixing Enabled="true" ShowFixButtons="false"></igtbl:ColumnFixing><igtbl:VirtualScrolling ThresholdFactor="10" TooltipVisibility="True" AverageRowHeight="29"></igtbl:VirtualScrolling></Behaviors></igtbl:WebDataGrid>
Also noticed that if you fix the columns server side it appears to work until you move/sort a column then it breaks in IE again.
This is definitely a clunky work around but hopefully it will help someone else having the same issue.
Hi tomhrvy,
Thanks for posting in our forums!
Thank you for sharing your workaround with the community.
I will look into this and see if I can find a simpler solution for you. I will let you know what I come up with sometime tomorrow.
We just started encountering this problem on all our grids and we are on version 2012.2. It was never happening up until a week or so ago, so it appears the latest version of Chrome has caused it. Look forward to hearing if there is a resolution other than upgrading.
Thank you.
Could you also confirm if this is still an issue in 2014 Vol1?
Hello All,
I am able to see this behavior after some testing with the latest Service Releases for some of our volumes.
Upgrading to the latest version of Infragistics 2012.2 appears to resolve this issue. The latest Service Release for 12.2 is 12.2.20122.2257.
For anyone using an earlier volume than 12.2, I am discussing this with my supervisor for further guidance on this.
I will have another update on this sometime tomorrow.
kal_patel,
Would you please let us know what build of 2012.2 you are currently using while you are experiencing this issue? Knowing this will help make it easier to track down what can be done to resolve this.
mondayuk,
The latest versions of volumes 12.2 and newer should not experience this issue. I have tested with 14.1.20141.2150 and the issue is not present.
The recommended solution to this issue is to update your applications to use Infragistics 12.2 or newer and to use the latest Service Release for that volume.
This issue is resolved in the latest service releases for Infragistics for ASP.NET.
Service Releases are available under your account at the Infragistics Website. To download the service release, log in to ‘Account’ and select ‘Keys & Downloads’. Select the Dev Tools tab and then click on the product name. Finally, select the 'Service Releases' tab and the available service releases will be listed below.
Please let me know if there are any further questions or concerns about this matter.
Please let me know if you have any other questions or concerns about this issue and I'll be glad to help.
