I am building webdatagrid using dropdownprovider dynamically.
Once loaded the dropdown the values are loadded correctly but when i click on the dropdown its show only empty container. It will not show the values.
other dropdown in the webdatagrid are showing correctly. but one those values more ie 100 items like will not show the values
Please urgent this issue please guide me.
Satya.
I'm just following up to see if you need any further assistance with this issue. If so please let me know.
Hi When you using your test project there is no issues. but when i am integrating the same code into my application then the dropdown list items will not display properly.
I am attached the extracted files from my application. Please something .css files are hiding the dropdown data.
Hello Satya,
I am not able to see your sample, in oreder to attach it please zip it.
See the attached extracted files from application
Please provide ASP Project sample which reproduces the issue or modify the provided one by me.
Thanks.
HI,
Please find the attached project for reproduce the datagrid dropdown display issue.
Please help me out resolve ASAP. its quite urgent i spent lot of time on this.
Please take look at line 173 in DrpdwnProvider1.aspx.vb from your latest attachment you are setting the dropdown container to have height of 0.
Hope this helps.
Hi Denis Georgiev,
Thanks a lot for the solution its works for me but if I remove the height. then there is showing the height which is very long. so how can i control dynamically the height based on the each item values in the dropdown?
