Other than the Firefox the ToolTip on graphs is not coming.There comes no text when you hover over on the data points on graphs.
It seems there is no such issue reproducible with the latest version. You could observe the expected tooltips under all browsers using our online samples at: http://www.infragistics.com/samples/aspnet/chart/creating-and-using-custom-tooltips http://www.infragistics.com/samples/aspnet/chart/adding-tooltips-to-a-chart
Could you add some more details? Please let me know that the exact version you are experiencing this issue with is, as well as what are the browsers versions this is reproducible with. A runnable code sample illustrating the issue or at least sharing the code in use could help further investigate this. It is of course possible you are using outdated version not being supported under latest browsers. For details consider the following resource: http://www.infragistics.com/support/supported-environments
Thanks for the quick response. Below are some more details
As the latest browsers versions were developed many years after 9.1.20091.1015 was released, it is expected to run into issues. This version is to be considered outdated. As previously stated, you could find what the supported browser versions of our ASP.NET product are at: http://www.infragistics.com/support/supported-environments. To match your requirements, it states you should use at least 13.1 and later. However, in order to ensure the best user experience in all major browsers in the near future as well, I suggest you to consider upgrading to the latest available 15.1 version.
