275
Setting 'SubMenuOpeningDelay' prevents submenus opening in Firefox
I have noticed that setting the SubMenuOpeningDelay to anything, causes a javascript error and prevents any sub menus from opening in Firefox (all other browsers are unaffected). The error is in the igWebDataMenu JavaScript file:
__showElement:function(sg, item, isFromKeyboard)
    if(sg == null || typeof(sg) == "undefined" || sg.style.display != 'none')
        return false;
*** Error: sg.style is undefined ***
For some reason the object 'sg'  (which I assume is supposed to be the subgroup object reference) is set to the number 0 (or some other number) when I debugged through the code. Leaving SubMenuOpeningDelay to it's default value doesn't cause this problem.
I can leave it at the default value for now, but this pretty much leaves the propery unusuable if it breaks cross-browser compatibility. Hopefully this can be fixed in the next release or a hotfix.
Cheers!
Craig Wilson
Parents
No Data
Reply Children
No Data
