100
JScript Errors when opening appointments
I am attempting to use WebMonthView and associated controls for scheduling.  When I double-click on a date to open the appointment dialog, I get the following error:
Microsoft JScript runtime error: Object expected
This occurs in AppointmentAdd.aspx on the line:
<body class="FormBackground" onload="AppointmentAddLoad()" style="overflow:hidden;PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-TOP: 0px" bottomMargin="0" leftMargin="0" topMargin="0" rightMargin="0" XMLNS:igtab="http://schemas.infragistics.com/ASPNET/WebControls/UltraWebTab" XMLNS:igtbar
="http://schemas.infragistics.com/ASPNET/WebControls/UltraWebToolbar">
The onload function AppointmentAddLoad is highlighted.  I am not able to debug into AppointmentAddLoad to determine what is happening.
I first encountered the error while attempting to use the controls in a new web application I am developing using NetAdvantage 2010.1.  I upgraded to 2010.2 and then 2010.3 and still get the error.
Next I downloaded and ran the samples.  To my surprise, they each ran perfectly.
I thought perhaps the problem had to do with the fact that initially I was not creating a data provider for the WebScheduleInfo object.  I do not want the UI talking directly to the database, so I decided that a generic data provider talking to a dataset would be best.  I created a test application to attempt this, and followed the directions in the online documentation article "WebSchedule Binding to a Data Set with WebScheduleGenericDataProvider".  The code appears to match the article's directions, but I am getting exactly the same error.
Why do the samples work but my code does not?
I'd appreciate any thoughts anyone might have.
Doug
Parents
No Data
Reply
  • 100
    Just a piece of additional information.  I believe the Samples, when they run, are using a standalone server similar to the development server in Visual Studio.  The code I am having trouble with is running on my local machine's instance of IIS.
    I have seen articles talking about ensuring that the AXD mappings are set to allow scripts to run.  I believe they are, but I'm concerned that there is some other setting in IIS that I am missing.
Children
