I have a requirement to filter results in a WebDataGrid by applying filter on Column CreateDate(DateTime) using 2 DateTimePickers i.e:
-There should be a DateTimePicker to select the starting date and there should be another DateTimePicker to select the Ending Date for the same Column CreateDate and the results should get filtered accordingly.
Currently,I am able to put a single DateTimePicker Control using DatePickerProvider Editor Provider.
However Is there any way to use 2 DateTimePickers as mentioned in the requirement above?
Please let me know for any clarifications required.
Hi MeghaDawahni1,
It has been some time since your post, however in case you still need assistance I would be glad to help.
The WebDataGrid currently supports the addition of only one provider per column. In your scenario I would suggest using a templated column with 2 WebDatePickers in the item template.
Please feel free to contact me if you have any questions.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://www.infragistics.com/support
