I am looking control similar to the attached file, where i can provide axis values can be drawn/updated based on the some settings. and values are updates time based
Hello Vinil,I believe the UltraDataChart can suit your needs. Depending on your data and how you want it presented, you will need to select the appropriate Series for your needs.If you are looking for the chart to update constantly as your data is updating, the UltraDataChart can be bound to a datasource, and will reflect any changes made to that datasource in real time.Please let me know if I can assist you further.Very respectfully,John VanZwietenWindows Forms Software Developer
Thanks for the fast information, but it does not suit my needs as UltraDataGrid support from 14.2 version onwards.
I am in a situation where i cannot used this version. I am using 11.2 version in the product for which we need this control.
Is it any possibility to use any other control which is available in 11.2 version where i can meet the requirement
Hello Vinil,
Please take a look at UltraChart, which is the older chart control and should be available to you in 11.2.
Please let me know if I can provide more information.
Thanks for suggesting the control.
I am trying to create the graph as mentioned using the UltraChart, but i am not able to create the same.
Is it possible to tell me how to create the graph using UltraChart
The chart should be as shown in the picture when no data is loaded. And when data is enable to read then it should be as Line/Spline.
I have determined that it is not possible to render a normal ScatterChart without data bound to it. I believe this feature may be possible using a Composite Chart, so I will continue investigating to determine for sure. You can expect my results within 24 hours of this post.
Hello John VanZwieten,
I am looking forward on the updates on your proposal to configure the Chart control to meet my expectations.
Thanks and Regards,
Vinil Kumar Sarode
Vinil,
I've investigated a few strategies that might accomplish the two requirements I see in your post:
1. Blank axes should be shown when no data is loaded into the chart.
2. The chart axes should be centered in the chart area.
The chart is not designed to render with no data loaded. But it may be possible to load a "false" data series and set it to transparent. This should give you the effect of the empty chart with axis rendered before you have data to render in the chart. You can then load your true series into the chart as needed. I will continue investigating this to see if I can make this option work.
You can expect my next update on this issue within the next 24 hours.
I've created a sample which demonstrates how to accomplish the two requirements I wrote previously. Please take a look at it to see how you could create the chart you need for your application using a similar strategy.
I have provided demo with the control provided by you. Thanks for the controls.
Further i have also created similar graph with UltraPictureBox control by drawing lines, while updating the picture box, it flickers alot.
//----Sample code ----
invalidate();
Suspendlayout() or BeginUpdate();
picgraph.refresh(); // Triggers flickering also
Resumelayout() or EndUpdate();
Tried with Suspend/Resume layout, Begin/End Update. and also set doubleflickkering and also Optimized flickering. Still the picture box flickering is still there while updating.
Similar operations with .NET picturebox, i didn't observed flickering. Since i wanted to use UltraPictureBox because more depth of visibility.
Let me know what could be the reason.
This all depends on what how exactly you are implementing this in the picture box. If you are setting the image of the picture box, this should invalidate the control itself, and you shouldn't have to invalidate it to trigger a repaint. If you are updating the data and then triggering an invalidate in that event, you shouldn't need to refresh. In fact, invalidating the control without refreshing should allow a repaint at a natural interval, so this would solve the problem if you are causing the flickering by forcing a repaint too rapidly.
To have a better idea of how to solve the flickering I would need to know more about how you are implementing this. Is the above code in an event, if so which? A small, isolated sample demonstrating your strategy would tell me a lot regarding this issue.
That being said, it may still be more worthwhile to try to use the UltraChart to accomplish this. What about the chart was unsatisfactory to you, perhaps we could address that?
