We are upgrading UltraWinGrid v18.2 from V17.2 for our system, and take no changes on CustomFilterDialog as default but it shows some overlap issue like follow, while it worked well in 17.2.
Comparing with sample, "+" and "-" should display at left of text and also symbols in operator combobox should also at left side.
Any hero/heroines has good idea on it?
Thanks.
Hello Ryan,
Thank you for posting. I followed the steps you suggested, created a sample of UltraWinGrid and open the custom filter and i was unable to reproduce the behavior you're describing , my Text are not overlaps/duplicate.
I have attached the sample project I used to test this. Please test this project on your PC; whether or not it works correctly may help indicate the nature of this problem.If the project does not work correctly, this indicates either a problem possibly specific to your environment, or a difference in the DLL versions we are using. My test was performed using version 18.2.20182.175.
If the project does show the product feature working correctly, this indicates a possible problem in the code of your application. It will help if you can provide a small, isolated sample application that demonstrates the behavior you are seeing.
Or, if this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back, or send a small sample project of your own if you have one.
Please let me know if I can provide any further assistance.
Sincerely,Divya JainAssociate Software Developer
TestSample.zip
Hi Divya,
Thanks for your reply. The issue on our side looks like the symbols (+, -, >...) are displayed in the center of the object. Is there a property that controls its horizontal alignment? Or, is it possible to remove the symbols and just leave the words there?
Jason Zhao
