I am using following Infragistics XamGrid Verison "v11.2.20112.1012"
Issue: When I try to click a cell the application crashes on Windows Server 2012, however it works perfectly fine in Windows 10.
Stack Trace:
Framework Version: v4.0.30319Description: The process was terminated due to an unhandled exception.Exception Info: System.ArgumentException at System.Runtime.InteropServices.Marshal.ThrowExceptHAonForHRInternal(Int32, IntPtr) at MS.Internal.Automation.UiaCoreProviderApi.CheckError(Int32) at System.Windows.Automation.Provider.AutomationInteropProvider.RaiseAutomationPropertyChangedEvent(System.Windows.Automation.Provider.IRawElementProviderSimple, System.Windows.Automation.AutomationPropertyChangedEventArgs) at System.Windows.Automation.Peers.AutomationPeer.RaisePropertyChangedEvent(System.Windows.Automation.AutomationProperty, System.Object, System.Object) at Infragistics.AutomationPeers.XamGridAutomationPeer.RaiseSelectionPropertyChangedEvent(Int32, Int32) at Infragistics.Controls.Grids.XamGrid.OnSelectedCellsCollectionChanged(Infragistics.Controls.Grids.SelectedCellsCollection, Infragistics.Controls.Grids.SelectedCellsCollection) at Infragistics.Controls.Grids.XamGrid.SelectCell(Infragistics.Controls.Grids.Cell, Infragistics.Controls.Grids.InvokeAction) at Infragistics.Controls.Grids.Cell.OnCellMouseDown(System.Windows.Input.MouseEventArgs) at Infragistics.Controls.Grids.XamGrid.XamWebGrid_MouseLeftButtonDown(System.Object, System.Windows.Input.MouseButtonEventArgs) at System.Windows.RoutedEventArgs.InvokeHandler(System.Delegate, System.Object) at System.Windows.RoutedEventHandlerInfo.InvokeHandler(System.Object, System.Windows.RoutedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(System.Object, System.Windows.RoutedEventArgs, Boolean) at System.Windows.UIElement.ReRaiseEventAs(System.Windows.DependencyObject, System.Windows.RoutedEventArgs, System.Windows.RoutedEvent) at System.Windows.UIElement.OnMouseDownThunk(System.Object, System.Windows.Input.MouseButtonEventArgs) at System.Windows.RoutedEventArgs.InvokeHandler(System.Delegate, System.Object) at System.Windows.RoutedEventHandlerInfo.InvokeHandler(System.Object, System.Windows.RoutedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(System.Object, System.Windows.RoutedEventArgs, Boolean) at System.Windows.UIElement.RaiseEventImpl(System.Windows.DependencyObject, System.Windows.RoutedEventArgs) at System.Windows.UIElement.RaiseTrustedEvent(System.Windows.RoutedEventArgs) at System.Windows.Input.InputManager.ProcessStagingArea() at System.Windows.Input.InputManager.ProcessInput(System.Windows.Input.InputEventArgs) at System.Windows.Input.InputProviderSite.ReportInput(System.Windows.Input.InputReport) at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr, System.Windows.Input.InputMode, Int32, System.Windows.Input.RawMouseActions, Int32, Int32, Int32) at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr, MS.Internal.Interop.WindowMessage, IntPtr, IntPtr, Boolean ByRef) at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef) at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate) at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr) at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef) at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame) at System.Windows.Application.RunDispatcher(System.Object) at System.Windows.Application.RunInternal(System.Windows.Window) at Program.Main(System.String[])
Please try upgrading to our latest version and retest. 11.2 falls outside our range of volumes supported with that OS and is also no longer supported for maintenance updates. You may refer to our supported environments page for more details.
