We are developing some lists and libraries using a managed metadata column. This is using a Term Store, which displays choices in a hierarchy, allowing multi-select. This is a standard SharePoint column type, I believe. Currently, I cannot get SharePlus to even display my first list that is using this column type. Is there a way to get support for this type of column in SharePlus?
Thanks and regards, Ellen Dickson
Hello Ellen,
Thank you for your support request!
I believe that you refer to managed metadata columns with cascading filters, right? What you select in column 1 filters the available values in column 2.
This isn't supported but you should be able to see the list. Can you confirm that the list is missing?
Looking forward to hearing from you,
Actually, when I went back to double check on this, I realized I had tried it before on an old level of SharePlus still on my machine that had an expired certificate. This time, I tried it on the current version w/all valid certificates, and it worked perfectly! So, never mind, apparently you already have this support in SharePlus! Thanks, Ellen
