Is it possbible to have views created in Sharepoint surface on the navigation of shareplus. I just created a couple of sharepoint views, which are public and available to mobile devices but they do not appear in Shareplus.
Any advice would be appreciated. thanks.
Hi bmor,
Thank you for posting at IG forums!
What you describe may be a cache issue. Try tapping the Edit button.
Then tap the list in which you have new views and tap the Reset Cache button.
This will clear the cached data and will force the app to read the list's data again, including the views.
I hope this helps. Please post back if you need further assistance.
Best regards,
Javier da Rosa | Solutions Engineer | Customer Service
Thanks for the response. I should have been more clear. Is there anyway to show the site navigation on the left pane of Shareplus? I have created navigation links to views in order to allow for filtering and to enable the movement of items from one view to another based on the field used for filtering.
I am using this in sharepoint to avoid the rather clumsy way of moving an item from one list to another.
Thanks..
Oh!
Navigation links can't be displayed in the left pane.
Do you need different views for the same list? If not then you may set their particular view as the default view and mark the lists as favorites in SharePlus. You may see your favorites only if you tap the "My Favorites" button at the bottom of the left pane.
Pre-authentication types, ticket options and failure codes are defined in RFC 4120. | Tree Cutting
