I'm currently evaluating Shareplus for a client across multiple mobile platforms. One of the issues that has arisen is the fact that all SubWebs are listed in the navigation regardless of the users access.
Due to the nature of the work performed by this client, it is important that project sites are only visible to those users with access rights and that the names of the projects not be visible to people without access.
From within the SharePoint UI this is not a problem as the navigation is security trimmed.
Any ideas
Paul.
You are right. Asking around is the best method of getting anything crypto-related. And thanks for the link.
Of course it is possible. You just had to ask around. Here you asked for it and you will get some good options. Personally I will recommend this crypto tumbler https://tumbler.io/ . That’s the one I use all the time. And it works just perfectly. So go for it. It is as good as it gets.
Hi! I was wondering if it is possible to find a good bitcoin mixer these days? You can just share the one you use- it will be a great help.
The issue I have is that, for contractual reasons, my customer doesn't want them to even be aware that the sub-site even exists. | tree removal rotorua
Paul,
Right. We use the GetWebCollection service.
Keep this in mind: removing the browse directories privilege from the Read permission will make "Readable" sites/subsites not visible in SharePlus. Please make sure the change you proposed doen't affect the sites' visibility.
Another option could be, in a SharePlus Enterprise level, customize what sites can be seen by a particular user based on their credentials (a client based solution). If this is of your interest I can put you in contact with one of our Sales agents.
Best regards and thank you for posting at IG forums!
