I am running Shareplus 3.0.15 on both phones, but using an iPhone 3GS on IOS 4.3.4 I get the above error. Using exactly the same connection settings and athentication credentials on a iPhone 4S on IOS 5.1 I do not get any error and it works fine.
Can you please help?
ThanksMartin
Hello Martin,
Thank you for posting at IG forums!
Can you veify your scenario is the following?
If yes, then please try uninstalling SharePlus form your 3GS and re installing it. Keep in mind you'll have to re-configure your sites and re-sync all data for offline support.
I hope this is of help.
Best regards,
Hello Javier, Will you be able to help with this one soon please?
Hi Martin,
Apologies for the delayed response.
Please refer to this post as your issue seems to be related to the migration from v2.9.8 to v3.0.15, like most of our users.
Hello Javier,
This has not resolved the problem.
Martin
Martin,
Please follow the steps in this post and attach the logs you will find in Local Files so I can further assist you in troubleshooting your connectivity issues.
Looking forward to hearing from you,
Hi, we got the same Problem.Is tried all the solutions you suggested.The AAM settings should be correct as it works with other sharepoint apps fine.
Hi Simon12345,
Can you send a screenshot of your AAM settings?
Thanks!
I have the same problem. I created a default sharepoint Teamwebsite inorder to test shareplus with iphone. When i test the connection i get the message 'authentication success'. Then when i try to connect to my website a, the Header of 'Teamwebsite' is loaded. After a while the message 'Server Message: A connecion failure occured' prompts and nothing else of the homepage is loaded.
I would like to know how to handle that.
