I have a few iPhone users who are missing various calendar entries on multiple days. The entries appear on our SharePoint website, but not in the SharePlus app. Is this a known problem?
Any suggestions are appreciated.
Have a nice weekend,
Brad Hemmi
BradBEMA,
I have created a support case for you (CAS-93214-T42Q92) so we can carry on troubleshooting this issue.
Please go to your IG account then My Support Activities for following up with your case.
You'll receive a message from me with instructions on how to send me the logs.
We'll post the results here once we've arrived to a conclusion.
No worries. Clearing the cache did not resolve the issue. I have the log files; how can I go about emailing them to you?
Hello BradBEMA,
Sorry for the long silence.
Please try to reset the list's cache (tap and hold the list's name > Reset Cache). This will force SharePlus to rebuild the list's structure.
If this doesn't work, follow the instructions in this post and send me all the technical logs you can.
Looking forward to hearing from you,
Have there been any new developments on this case?
EDIT: I've tried all views and all data is missing in each view.
From what I can tell there are no filters being applied.
I did find something else out that might be helpful. April 30th in SharePoint Calendar has some events listed. When I look at April 30th in the SharePlus calendar it is empty. However, if I select April 30th in the SharePlus calendar, and then click the icon on the top right and select "View on web" the correct events for that day do display.
Hopefully that helps!
