Running the latest version of SharePlus on IOS 6.x.x.
Have issues opening an Excel 2010 document saved in .XLSX format.
Hello Tanju,
Thank you for your post. I have been looking into it and I can say that in order to open the document you should double click on it and a popup will appear with information about the file. After that you should double click over the icon with the paper. Then the document will load in the Preview app. Please let me know if this helps you, if not could you please tell what are the steps you follow in order to open the document, what is the version of SharePlus you use and is there any error that occurs when you try to open the excel file.
Regarding that space on disc issue. This is a server error. There are several articles out there that explain how to fix this and possible workarounds.
Roll Off Dumpsters
Share plus is the latest version of excel which read documents in any format and it resolves all issues regarding new data files. These new versions support college term paper writers at reliable service and read documents without changing into different formats. You can follow the given instructions to open files and it is helpful if you are using share plus for the very first time.
