When Shareplus is initially launched on iPad or iPhone the following error occurs:
404- Not Found Service response in unexpected format, please review your configuration.
Once the app loads into memory, everything functions correctly. No error occurs when opening Shareplus once it’s loaded in memory.
Juan & Javier, is this the correct form for this question? Any suggestion on how to proceed would greatly be appreciated.
Paul
Looking forward to hearing from you,
Gonzalo T Technical Support Engineer I Enterprise Mobility Infragistics, Inc.
Hi Gonzalo,
Is this happening when you try to connect to your site or when trying to browse a library or a list?
We opening the app for the first time(not in memory), initially connecting to the site, no issues browsing list or lib. After the 404 error msg.
If the issue is with connecting to a site:
no issues connecting after the error msg.
Is your site published via Forefront? No Mobile Iron
What authentication mechanism did you use to connect to your site with SharePlus? MobileIron
What version of SharePoint are you connecting to? 2010
If the issue is with browsing a list or a library: no issue browsing
Is the list customized? In what way? No issue with custom list or libraries
And please follow the steps in this forum post http://www.infragistics.com/community/forums/t/92048.aspx in order to enable and send us the
SharePlus' technical logs after reproducing the issue a couple of times.
The error msg occurs before the app initializes, I couldn’t get the log to capture any information.
Issue seems to be related to when the social feature was added.
Hello Paul,
Is this happening to more than one device?Are you testing an enterprise build?If so, could you provide us with test credentials in order to get console logs on our end?
Please let me know and I'll provide you an email address for you to send the credentials.
Regards
Spent time on a support call today, believe the issue is tracked down to a configuration setting. We hope to have the issue resolved tomorrow.
I have a number of other questions, which I’ll post in a different thread.
I'm writing to you in order to check if you were able to solve the 404 error.
If so can you let us know what was your work around?This way the solution can be published here for other users to see.
I will keep this case open for another three days while I wait for your response. If at that time you haven't responded, I will close this case as inactive. Please note that closed cases may be reopened within thirty days of closure.
Best regards.
Gonzalo TTechnical Support Engineer IEnterprise MobilityInfragistics, Inc.
I'm writing to you in order to check if you have further questions.
Gonzalo T Associate Support Specialist Enterprise Mobility Infragistics, Inc.
Waiting on the admin to make the update, the fix will not be applied until late this week, you can close the case. I'll open a new issue if there is still a problem.
