I have a VB.Net Web Forms Application. In that I have a requirement where in an UltraWebGrid, an UltraGridColumn must contain a multi-select dropdown. I am using Infragistics4.Web.v11.1. Please let me know if it is possible to do it with this version or whether this feature is supported in UltraWebGrid for Web Forms. If this feature is possible, please provide a solution.
Archa S A
Thank you for contacting us!
Please note that the version you are using is retired several years ago and understandably would not work with modern browsers that were released after the last volume of the classic controls, which was Infragistics NetAdvantage v11.1 of ASP.NET and also is no longer supported. The product lifecycle is stated in the following page:https://www.infragistics.com/support/product-lifecycle.
The only possible solution in this case is to use a product that is supported under newer browsers, which you can identify in the supported environments page at:https://www.infragistics.com/support/supported-environments.
So what you could do is to upgrade to the new ASP.NET Ajax tool-set. You can take a look at it at:https://www.infragistics.com/products/aspnet.
