I have an application using tabs to switch between different views. On these tabs I have XamGrids that allow filtering. Now when a filter is entered it works find but if the user switches to another tab and then back to the tab with the filtered XamGrid all rows are shown. The filter text is still there but it won't filter until I change the filter on any column.
This is in version 13.2. I was using version 12.2 before and had no such problem with that version. Could you please check this and maybe provide a fix for this issue?
Thanks!
Thank you for your post. I have logged this behavior with our developers in our tracking system, with an issue ID of 158235. I have also created a support ticket on your behalf with number CAS-130345-S2G3W8 in order to link the development issue to it so that you are automatically updated when a Service Release containing your fix is available for download.
Sincerely,
Krasimir, MCPD
Developer Support Supervisor - XAML
www.infragistics.com/support
Does this problem also exist with Custom Row Filters that are set?
We are in the middle of migrating from Silverlight 4 to 5 (we now use the latest Infragistics with latest SR). And find that our previous code stopped working.
It seems that Filters that I add via are getting lost as well!
cl.FilteringSettings.RowFiltersCollection
Can you confirm if this is a related problem or not?
Best,
Mark Monster
Yes, as far as I can see all filters are lost once you switch the tab and go back.
Thanks for your confirmation Ruud. Hope they fix it soon.
